Price: $139.99
(as of Mar 21, 2025 23:15:17 UTC – Details)
AIMTOM 42000mAh 155Wh Power Station, Emergency Backup Power Supply with Flashlights (Solar Panel Optional), for Camping, Home, CPAP, Travel, Outdoor (110V/ 100W AC Outlet, 3X 12V DC, 3X USB Output)
▲ ONE POWER GENERATOR FOR ALL YOUR DEVICES: Power up your laptop, stereo or any other home appliances via the 110V/100W AC outlet. Use the 3 x 5V USB outputs to charge your mobile phone, iPhone, iPad, GPS or action cameras while the 3 x 12V DC outputs are perfect for car refrigerators, fans and more.
▲ TAKE YOUR POWER SUPPLY WITH YOU ANYWHERE: Even though our power station features a HUGE 42000mAh lithium battery, it weighs ONLY 3.48lbs. Plus, the comfortable and ergonomic handle will make carrying your outdoor emergency power sources a breeze. Just slip it in your car trunk and embark on your next adventure.
▲ SO QUIET, EFFICIENT POWER: Rest assured that your portable battery will not disturb you or your loved ones, since it utilizes a built-in power inverter and runs quietly. It can be recharged via supported solar panels (Not included), car port, or AC wall outlets. Its built in MPPT controller automatically optimizes charging process and maximizes power extraction from solar panels under all conditions.
▲ ADVANCED BATTERY MANAGEMENT SYSTEM: The built-in BMS protects you against overcurrent, overvoltage, and over-temperature, ensuring the safety of you and your devices and prolonging battery life. It also features a built-in cooling fan to avoid overheating when charging.
