Price: $15.99
(as of – Details)
Enhance your Emergency Preparedness with the Crank Emergency Weather Radio
The weather radio provides you with tools to use in emergency and non-emergency environments.
The radio has 2 LED flashlight, an SOS alarm, 480mAh rechargeable batteries, FM radio broadcasts access, and power options to provide emergency power.
Ideal for Outdoor Activities: Camping, Hiking, Kayaking
Made of strong premium impact-resistant ABS material, ideal for both indoors home/office use and outdoor activities, such as camping, hiking, kayaking, etc. It can be used as a backup battery via the following methods:
USB Charging: Built-in 480mAh Connect the radio to a power source like a laptop and it takes about 2 hours to fully charge the radio.
Hand Crank: Turning the handle to start the generator, spin the handle for 1 minute at the speed of 150 RPM, it can be used for 10 minutes of radio play and 20 minutes of flashlight
Important Notes:
When the radio is fully charged, the radio can provide 5 hours radio play ( depending on the sound volume), 10 hours of flashlight and 70 Minutes of Siren Alarm.
We recommend USB charging in advance, hand crank is to used for emergency, it may take more time to activate the radio.
For safety concern, please don’t charge external devices when the radio is powered by the Polymer Li batteries as Polymer Li batteries are easy to get hot when charging the external device.
2 Ways to Power On
The AiMoxa FM emergency weather alert crank radio keeps you informed in case of severe weather or civil emergency with multiple sustainable power options: USB Charging, Hand Crank.
2 LEDs Lighting / 0.5W SMD LED High
0.5W Bright LED flashlight will always light up the darkness, no longer have to worry about power outage. And the 2 LEDs lighting let you enjoy more lighting choice.
WE HAVE PREPARED MULTI-FUNCTION EMERGENCY TOOLS FOR YOU:
AiMoxa portable radio is not only an innovation across times, but also a perfect integration of various emergency equipment. Easy to carry.
A Worthy Weather Radio Recommended by the Department of Homeland Security
Having a Weather Radio in your home and workplace could save your life. The AiMoxa FM Weather radio is designed to broadcast special frequencies and alert owners of hazards. You cannot rely on television programs to warn you of an approaching tornado when the power is out. Only a weather radio, which is equipped with a backup battery, is only the truly fool-proof way to get your severe weather warnings. So, it is a must for the family emergency box.
[POWERED LIGHT SOURCES] Compact sized flashlight radio with 0.5W SMD and 2LEDs Torch (more than 100 Lm) can provide enough output to keep you and your loved ones out of the dark in an emergency situation, camping etc.
[HIGH-DECIBEL WARNING FUNCTION FOR SOS] Emergency Self Powered Radio can Send Out a ≥120dB Distress Signal For Help Uninterrupted (≥70 Minutes).
[SELF POWERED] Manual hand crank to wind up the internal battery; Micro USB charging can also supply enough power to keep the radio, lights, and SOS alarm ready to go when you need it most.
[POWER BANK WILL KEEP YOUR DEVICES POWERED] Emergency radio incorporates a 480mAh power bank capable of providing emergency power to any small tablet or iPhone & cellphone.
