ACOPOWER 500 Watt Solar Panel Kit, 5PC 100W Polycrystalline Off-Grid System Solar Kit for RV Home Marine +40A MPPT Controller+Z-Brackets+Y Connectors+Solar Cables+Cable Entry Housing
Price: $1,479.99
(as of Jan 05, 2025 04:15:17 UTC – Details)
[Ideal Choice for Permanent Installation] Advanced laminated technology and long-lasting ETFE material of 100W polycrystalline solar panel supports high light transmittance, scratch-resistant and easy to clean. And anti-reflection tempered glass and corrosion-resistant aluminum frame reinforces safety and impact resistance, which allows each panel to withstand high wind (2400Pa) and snow loads (5400Pa). Solar panel for home is perfect for permanent or semi permanent installation.
[Monitor & Protect Devices] 40A MPPT uses maximum power point tracking technology and automatically regulates charging profiles relative to ambient temperatures, providing the best level of charge in any condition and protecting against over-charge, over-discharge, overload, and short circuit. User programmable for battery types, load control etc, via PC software or remote meter MT-50.
[Wide Application & Compatible]Solar Kit for RV. Solar panel kit is designed for RV, cabin, rooftop, caravan, shed, greenhouse, boat, back-up and remote power use, which can be connected in parallel for 12V battery charging or in series for 24V battery charging. And compatible with lead acid, AGM, gel, and lithium batteries. 40A MPPT of 500 Watts RV kit allows expansion to 1040W in series and 520W in parallel.
[25-year Power Output Warranty] We offer a 25-year transferable power output warranty on solar panels and 1-year warranty on rest of the kit components. ACOPOWER solar panels are factory-automated production without manual participation, so the probability of damage is low. If the panel you received is damaged due to transportation, please contact us as soon as possible.
