8000mAh Emergency Weather Radio, AM FM NOAA Weather Alert Radio Battery Powered, Portable Solar Hand Crank Radio Flashlight Cell Phone Charger, Compass for Camping Outdoor Emergency, SOS Alarm
Price: $34.99 - $27.83
(as of Mar 08, 2025 03:00:35 UTC – Details)
[8000mAh Rechargeable Battery]The battery capacity of this emergency radio is 8000mAh, which can be used for LED lighting for more than 29h in far beam, more than 25h in dipped beam, more than 15h in far & dipped beam, and more than 38h in reading lamp. It can be used for broadcasting (meddle volume) for more than 72h. When you are going outdoors or power failure at home, connect your devices to the two USB output ports to let your electronic devices charge.
[3 Modes Flashlight & Reading Lamp]The emergency crank radio be used as a flashlight and reading lamp. The flashlight has 3 modes (far, dipped, far & dipped beam), and it can provide enough output to keep you out of the dark in an emergency or power failure. The reading lamp can also be used as a sleeping light when you need it.
[3 Charging Modes]There are 4 power indicator lights in this solar powered radio, which can show you the power capacity. You can be charged this noaa weather radio by connecting it to a type-c cable. When you are in an emergency, turn the hand crank or use solar power to charge this emergency hand crank radio. Besides, you can also turn the sos alarm on to give you support when you going outside or waiting for rescue. And the compass attached to the hand rope can guide you when you lose your way.
[What You Get]Constructed with IPX3 waterproof level and durable ABS material, this emergency crank radio is very suitable for outdoor activities, especially on rainy or snowy days. Besides, you can get 1*Emergency Weather Radio,1*TYPE-C Charge Cable, 1*Compass, 1*Wrist Strap, and 1*Use Manual. Also, we provide you with 24h customer services, if you have any problem, please feel free to contact us. And all the products we sold have a full 18-month warranty against manufacturing defects.
