Price: $169.99
(as of Mar 27, 2025 07:15:23 UTC – Details)
ATPTK, THE EXPERT OF VEHCLE CAMERAS.
We are professional, in the field of vehicle camera for more than 14 years.
This is a single camera kit. It can be used for any kinds of large vehicles, such as buses, box trucks, pickup trucks, garbage trucks, flatbed trucks, dump trucks, street sweeper trucks, refrigerator trucks, motor homes, vans, skid steers, farm tractors, combines, cotton pickers, crop sprayers, bulldozers, snow plows, forklifts, excavators, heavy equipments,etc.Camera can be mounted at the back/front/side of your vehicle.Monitor can be mounted on the roof of the cab, or on dashboard.7″ AHD 1080P Single view(no split function) monitor with two way video inputsPowered by vehicle power DC12-24V. Red wire to ACC 12-24V positive , and the black wire to negative (GND).Trigger wires are for turning signal power to make the monitor display when turing or reversing, or kept blank to display all the time.
High Resolution 1080P
High resolution 1080P monitor with digital LCD panel. It gives a super clear color image.
Normal/mirror image
Image can be set as normal, mirror or up-side-down by menu.This allows the camera to be mounted as rear view, font view or side view.
Adjustable Guide Line
When parking, with the guide line or rear distance scale on screen, there is no more guess for you if the bumper gets closer to the object behind.With the guide line, it helps you parking faster and safer.Guide line can be adjusted by menu. You can set your own distance value on the guid line.
Take Up To 2 Cameras
7″ AHD 1080P single view (not split)monitor can take up to 2 cameras, AV1/AV2.If the monitor takes two cameras, camera for AV1 will be on all the time to surveil, and when you back up, the monitor will be activated to display AV2 camera by the triger wire which is powered via the backup light, then you can see what is behind your vehicle.In this kit, it inlcudes only one camera.
AHD 1080P Waterproof Camera IP69K
This camera has the highest level of waterproof and dustproof rating IP69K. When raining, you also can drive safely.And it also has 10G vibration resistance rating.This is a mini size camera, especially for space-limit installation.
It is not only suibale for trucks, bues, caravans, etc., it is also suitable for heavy equipments, farm tractors, skid steers, etc. in extreme condition.
Night Vision Camera
Our camera has 5pcs 850Nm IR lights. When driving at night, with our camera, you are still able to see what is behind your vehicle.
Transient Voltage Suppressors (TVS) Built-in
The transient voltage often ocurs in the circuit of your vehicle when winding up/down the window, turning on/off the air-conditioner, etc. It may damage some devices in your vehicle, inluding backup cameras. No worry!Our monitor has been built-in with TVS to protect backup camera system from being damaged by the transient voltage.
What is in the package
7″ AHD 1080P Single View (No Split Function)LCD monitor X1AHD 1080P Waterproof camera X1Monitor U-type bracket, sunvisor and screw X1Monitor power cable X149ft extension cable X1
【MONITOR】7” color monitor with U-type metal bracket and with 1080P resolution.It is not waterproof. It is compatible with most of the vehicles with a free power input range DC12-24V and supports with max 2 cameras. TVS and ESD device is built in to protect the monitor from being damaged by the transient high power of vehicles and the electro static as high as 8kv. And this monitor only supplies camera which is in use with DC12V, it saves energy. It is compatible with PAL/NTSC/AUTO.
【HEAVY DUTY CAMERA】It is color camera with the resolution of 1080P, provides super clear and real color image. The viewing angle is 120 degree. With waterproof rating IP69K(the highest level), with night vision. So it works perfectly in kinds of weathers. With Heavy duty, 10G vibration-proof rating, it works well with the vehicle which has intensive vibration in extreme conditions.
【Unique Selling Proposition】①.①.The monitor has three modes for option by menu to lighten the screen at day time and darken at night, not glare. ②.Monitor has a built-in protector for protecting monitor from being damaged by power polarities reversed. ③With built-in innovative system previous option settings memory even after it’s turned off. ④.Camera’s image can be set as mirror, non-mirror or up-side-down by OSD menu. ⑤Distance grid line can be turned on or off and set by OSD menu.
【Unique Selling Proposition】①Monitor has 2 trigger wires. Monitor will be triggered to be turned on automatically to display camera image when reversing. After reversing, the monitor will be back to the pervious mode. ②This system has two viewing options(view when reverse or remain on continuously). ③We uses waterproof Aviation 4-pin screw connectors, NO BNC/RCA. ④Easy to install. ⑤Two-year warranty and life-time tech support.
FAQs:1. Why buttons not work? —Disconnect the trigger wire, it will work. Trigger wire needs to be connected to power of rear lamp. 2. Remote not work. —Remote doesn’t have battery,because it is forbidden by shipping.
【Customer Service】When you recieve the item and find the item defective, missing parts, not working or don’t know how to connect the wires, please don’t worry, the first best step is to turn to our ATPTK team via the Amazon Message immediately. We are keeping our eye on all the messages from our customers, and will fix your issue perfect.
