Price: $52.99
(as of – Details)
【FM/NOAA Weather Radio】With the latest chip and telescoping antenna, the NOAA weather radio has excellent reception, clearly receiving 7 NOAA weather channels and FM channels to keep you up to date with the latest weather trends and news in your area, to be well-prepared and stay away from tornadoes, hurricanes, winter storms, earthquakes, tsunamis, floods, wildfires, and more. Having an emergency weather radio in your home or RV is essential.
【4 Ways To Charge】The emergency radio has a built-in 6000mAh rechargeable battery that is ready for emergency power needs. The weather radio supports Type-C cable (included) charging, Type-C charging is the fastest and primary charging method. It can also be charged by solar panel and hand crank. The radio is also equipped with a AAA battery compartment at the bottom of the radio (AAA batteries not included). The multiple charging options will keep the radio running in case of emergency.
【2 Modes & 4 Levels Adjustable Reading Light】Different from the other emergency weather radios,the reading lamping of the emergency radio has 2-mode & 4-level adjustable brightness which could be touch-controlled to meet the different lighting needs for reading. In addition,the radio’s handle and base design makes the radio perfect for camping or experiencing RV life.With a emergency radio that has multiple use scenarios,it is an item that will come in handy on any given day.
【Multi-Function & Reliable】Combines NOAA, emergency power, SOS Alarm, reading lamp, camping light and so on, the emergency radio is a must-have item for emergency. Also, we back this emergency radio with an 18-month warranty and 24-hour customer service team support. If you have any questions about our emergency weather radio, please contact us and we will provide you with a solution asap. Choose our emergency radios with confidence, and we will do our best to help you.
