5000mAh Emergency Weather Solar Radio: Missonchoo Hand Crank AM/FM/NOAA Alert Radio 4 Ways Powered with Flashlight | Cellphone Charger | SOS Alarm for Survival Camping Home Outdoor
Price: $29.99
(as of Apr 08, 2025 00:00:41 UTC – Details)
Emergency_Weather_RadioEmergency_Weather_Radio
WHY Missonchoo Emergency Weather Radio
Specifications:
FM: 87~108MHz
AM: 520~1710KHz
WB: 162.40~162.55MHz
L*W*H: 6.02*1.85*3.03in
Item Weight: 358G(0.78lb)
Built-in 5000mAh/3.7V Rechargeable Battery
IP rating: IPX3
Flashlight: 2W/100LM
Attention: This weather alert radio is water-resistant. It can be used reliably in adverse weather conditions, aboard watercraft, etc. But unit isn’t waterproof. Do not immerse it in water
Rugged_Life_Saver_RadioRugged_Life_Saver_Radio
weather radio 4 power sourceweather radio 4 power source
4 Power Sources
Emergency Crank Radio: The hand crank can be used to charge ER717 life saver radio in extreme conditions.
Battery Operated Weather Radio: Insert 3 AAA batteries for instant use, and the radio still can be used as a cellphone charger.
Portable Radio Solar: ER717 emergency radio can be charged by the solar panel. Keep the solar emergency radio powered anytime.
USB Charging: Plus the type c USB connector into the input port on the side of the rechargeable radio. It takes 2-3 hours to fully charge.
Package List: 1* Emergency Weather Radio 1*Type C Cable 1*User Manual Lanyard and Hook
simple small survival radiosimple small survival radio
weather radio lcd displayweather radio lcd display
noaa weather radio portablenoaa weather radio portable
Simple Operation with Indicator
The radio has four indicator lights: manual/solar charging radio, signal indicator, power indicator, alarm indicator. These lights make the operation easier
HD LCD Display
Unlike most weather radio on the market, Missonchoo ER717 weather radio has HD LCD screen, and is designed to visualize the power, to the greatest extent for daily use
NOAA AM/FM Radio
Missonchoo upgraded survival radio is equipped with an antenna that extends up to 15cm (5.9inch) and rotates 135°, give you more dependable access to AM/FM NOAA weather broadcasts
portable_crank_radioportable_crank_radio
sos radiosos radio
weather radio with mp3 playerweather radio with mp3 player
Portable Crank Radio
After constant improvement, ER717 weather alert radio was developed using a lightweight but rugged IPX3 water-resistant metal shell. The packaged lace and hook make this hand crank radio more portable(Hook and Lanyard included)
SOS Alarm
Missonchoo emergency radio has a built-in dynamic speaker, with clear SOS alarm. No matter what kind of dangerous situation you are in, you can quickly attract the attention of others with ER717
MP3 Function
Upgraded Missonchoo solar radio has a 3.5mm headphone jack. Use external headphones to listen to the radio and enjoy your comfortable leisure time
all in one weather radioall in one weather radio
Survival Radio with Louder SOS Alarm: Missonchoo portable weather alert radio has upgraded the built-in dynamic speaker after repeated test. When you get lost outdoors or fall into other emergency situations, you can use it to get faster help with clearer and louder alarm. Best emergency radio kit for camping, hiking
Water-resistant NOAA Radio with Voice Broadcast: With Built-in Professional Speaker and upgraded telescoping antenna, Missonchoo emergency weather radio will dependably receive up to the emergency weather forecasts and emergency news broadcasts from NOAA and AM/FM stations. Press any key to play the voice broadcast
Digital AM FM Weather Radio Self Powered with Flashlight: Upgraded ER717 emergency weather radio with solar panel has a built-in 5000mAh rechargeable battery, which can be charged by solar, hand crank, using TYPE-C, 3*AAA batteries. Missonchoo weather flashlight radio has 3 Flashlight Mode for more lighting needs. Reading lights will greatly help you get up at midnight and avoid waking up others
Portable Emergency Preparedness Radio for Home Outdoor: Missonchoo emergency survival radio with 4 ways power source is reliable and necessary for home use and outdoor travel, be ready for all hazards, such as hurricane, storm, tornado, earthquake
