4Patriots Liberty Band Emergency Solar Radio: NOAA Weather Warning Radio, Portable Power Bank, Charger & Flashlight – Solar Powered, Hand Cranked 3.7V/600 mAh Lithium Ion Rechargeable, AM/FM 7-channel
Price: $2,539.00 - $59.98
(as of Mar 28, 2025 06:30:32 UTC – Details)
3 MORE WAYS TO CHARGE: No sun? No problem. You can “fast charge” your emergency solar radios with the AC cord before the storm hits. Or use the hand-crank to get alerts in a storm. And of course, everyday batteries work great too.
NOAA WEATHER-ALERT PROTECTION: Listen to weather forecasts and news broadcasts24/7 from NOAA and AM/FM/SW stations. Plus, you can turn it to weather-band alert mode and your radio will stay quiet until you need extreme-weather alerts.
POWERS YOUR CRITICAL DEVICES: Use the power inside the Liberty Band Radio to give your phone or other critical devices a little extra “pinch” of power when you need it most. Simply use the cord that came with that device. Anything that charges via USB will work with your radio.
3-LED FLASHLIGHT: Built into your radio, you’ll get an ultra-bright flashlight. It provides lifesaving visibility for you and your family, even if the world goes dark.
