2023 Newest Emergency Radio, 4000mAh Power Bank Solar Hand Crank Radio, AM/FM/WB/NOAA and Alert Portable Weather Radio, Multifunctional SOS Alarm Survival Radio with Flashlight for Outdoor Home
Price: $29.99
(as of Apr 08, 2025 06:30:30 UTC – Details)
4 Ways to Charge: In normal times, we can use the type c data cable delivered together to charge. But when an emergency occurs, there may be a power outage. At this time, the hand crank generator can be used for hand-crank charging, solar charging, and replacing AAA batteries. A variety of charging methods are a good solution to the situation of no electricity. When mobile phones become a necessity of life, this charging method also provides a new solution for charging mobile phones.
Emergency Light & SOS Alert: When there is a power outage, this best emergency radio’s built-in flashlight and reading light come in handy. This will give you a sense of security at night. When you are in an emergency and no one knows about it, the radio’s built-in SOS alert will prompt others to find you and help you. A must-have for casual camping, backpacking, or wilderness survival.
High-definition LCD Display: Unlike other products, we have updated the channel display method. Through the LCD screen display, you can more directly understand the current channel and battery status from this NOAA radio. Ensure AM/FM/WB Reliable reception, fast scan, and find the channel you need. Fully upgraded materials and features make this upgraded radio durable enough to handle all emergencies.
Portable Radio & Headphone Jack: This portable radio is only 350 grams, equivalent to the weight of a mobile phone. The size is 6ร—1.8ร—3 inches, very small and portable. There is a 3.5mm headphone jack on the side, allowing you to enjoy the broadcast alone without disturbing others. This unique radio will be everyone’s Essential supply, whether at home or in the field, it can provide us with comprehensive help.
