200W Solar Generator Kit, Powkey 120Wh/33,000mAh Power Bank with 110V AC Outlet, 6 Outputs Solar Generator External Battery Pack with LED Light for Outdoor Camping
Price: $169.99
(as of Apr 06, 2025 08:30:29 UTC – Details)
Wattage :
120 watts
3 WAYS OF RECHARGING: This 120Wh portable rechargeable power station has 3 methods to get recharged. The package includes two adapters, you can charge it via wall socket or car adapter(12V). And it also can be recharged under the sun with a solar panel(15V-24V/2.6A)(NOT included).
MULTI-OUTPUTS: The portable solar generator is equipped with 1* AC outlet (110V 200W ), 2* USB ports (5V, 3.1A total),1* USB-C port , 2* DC Outputs(9~12.6V/10A) which can charge smartphone, tablet, camera, mini refrigerator, night light, mini fan, CPAP and other electronic devices under 200W.
HIGH CONVERSION EFFICIENCY: With a 22% high conversion efficiency of this 60W mono crystalline solar panel, it’s able to produce electricity in low light outdoor environment to charge your devices in shorter time.
FOLDABLE & KICKSTAND DESIGN: This 60W solar panel only weighs 6.6lb( 3KG), and with a folded size of 46x36x5.5cm( 18.1×14.2×2.2in), it’s ideal for camping or outdoor working, and compatible with most power station in the market.
