Price: $85.99
(as of Jan 24, 2025 11:45:19 UTC – Details)
200W Portable Power Station, Powkey 120Wh/33,000mAh Power Bank with AC Outlet, 110V 6 Outputs Power Generator External Battery Pack with LED Light for Home Use and Outdoor Camping
3 WAYS OF RECHARGING: This 120Wh portable rechargeable power station has 3 methods to get recharged. The package includes two adapters, you can charge it via wall socket or car adapter(12V). And it also can be recharged under the sun with a solar panel(15V-24V/2.6A)(NOT included).
EMERGENCY FLASHLIGHT&COMPACT HANDLE: The portable battery pack weighs only 3.2lbs, and a comfortable and ergonomic handle makes it easy to take anywhere. This solar power station is built with dual white LED flashlight to meet your different needs. Press the flashlight button to switch on the light and single press the button to switch to blink/ SOS mode, Press the button again to switch off. When you go out camping or experience power outages, this power station may be a good choice.
MULTI-OUTPUTS: The portable solar generator for home use is equipped with 1* AC outlet (110V 200W ), 2* USB ports (5V, 3.1A total),1* USB-C port , 2* DC Outputs(9~12.6V/10A) which can charge smartphone, tablet, camera, mini refrigerator, night light, mini fan, CPAP and other electronic devices under 200W.
WHAT YOU GET: 1 x 120Wh Portable Power Station, 1 x Car Cigarette Lighter Adapter, 1 x AC Power Adapter, 1 x Car Charging Cable, 1 x User Manual,we also provide 7*24 hours customer service and 24 months product guarantee.so you can worry-free
NOTES: Limited Appliance Wattage<200W, such as lamp, Electric Fan, TV, Game Machine, etc. AC will shut down when the power station is short-circuited or power overloaded. Remove the device and the power station will return to normal from short-circuit or overpower protection in a few seconds. Repress the AC output button to switch on AC output again.
