Price: $5.99
(as of Apr 08, 2025 09:45:25 UTC – Details)
200PCS Mini Split Rings Jump Ring 12mm Double Loops Keyrings Silver Metal Rings Connectors Keychain Flat Rings for Jewelry DIY Arts Ornaments Home Car Keys Attachment
【Color】: Silver
【Material】: The round keyrings are made of metal alloy which make them strong and sturdy.not easy to break or deform, anti-corrosion and anti-rust, can be kept for a long time use, their classic and the surface is also not easy to fade.
【Sufficient amount】: Total 200 pieces of keyrings,that will meet your needs for daily use or craft projects
【Fine workmanship】: Metal split rings are smooth in surface,Each open ring comes with 2 layers design, keep them securely closed so that the attachments won’t slip off from the rings, the design also allows items to be conveniently added or removedThe double loops of each ring are firmly closed for tight connection,no need to worry about your keys falling apart. They have sufficient tension to easily move items in or out of them without deformation.
【Wide Applicatiom】: The round flat split ring is good for Perfect for organizing your keys, hang cards, dog tags,DIY accessories, making arts project and so on. Also intended to connect accessories to a larger key ring.
