2 Packs of zinc Alloy Scratch-Resistant car Key Ring Clip Coil Cool Ring Buckle Key Ring Men’s Business Gifts (Grey + Silver)
Price: $6.99
(as of Mar 21, 2025 20:30:25 UTC – Details)
MaterialThis keychain made of high quality zinc alloy, sleek and durable, solid construction and not easy to scratch. Convenient to useSleek design allows easy addition or removal of keys in one smooth action, which helps you keep keys organized and easily accessed, at the same time protect your nails.
Department ‏ : ‎ Womens
Date First Available ‏ : ‎ April 22, 2021
ASIN ‏ : ‎ B09371TKL7
The zinc alloy material is solid, well-designed, complex and simple, making the clip unique. The key ring itself is very independent and can be swiped by the key.
It has a primary key and an auxiliary quick release hook that helps you keep the keys organized and easily accessible.
HIGH QUALITY MATERIAL- Built with heavy duty zinc alloy, adopts advanced integrated molding technology for Anti-Scratch & Never rust, and well-constructed for durability.
FUNCTION- It has a main key ring and an quick release snap-link buckle hook, which helps you keep keys organized and easily accessed to purse, belt loop, belt, pants, wrist lanyard in security.
SIZE-length 9.5cm(3.7 inch), width 2.5cm(1 inch), dia of the ring 3.3cm(1.3 inch) , Net Weight: 38g
