Price: $12.99
(as of Mar 26, 2025 20:45:25 UTC – Details)
Warning
1.Due to air mail regulation, the lighter is EMPTY before shipping out. Please refill with high quality butane gas before using.
2.When you adjust the flame to lowest setting, there will be no flame for safety design.While on highest setting, the flame will last for 1-2 seconds after releasing the ignition button because there will be a little remaining gas on the burners, please pay attention. We recommend to adjust the flame to medium level when using it.
4.Prohibited to face the body or inflammable things when using.
5.Keep lighter beyond the reach of children.
6.Burning Time: No more than 10 seconds.
7.DO NOT put it under high temperature (<50℃)
How to refill your lighter:
1. Before refilling a lighter,please drain any remaining fuel from the lighter. Using the small screwdriver press the fuel-refilling nozzle to remove the leftover fuel.
2. Turn the flame regulator until it stops to turn off the fuel flow before refueling.
3. Point the fuel nozzle up and push the container of fuel into the lighter. Turn the fuel nozzle down and wait while the lighter refills. It is important not to pump the fuel can into the lighter while refueling because this may cause the fuel tank to burst.
4. Once the lighter is refilled, allow it to rest until the fuel becomes room temperature. Butane fuel is cold while refilling. It will expand as it gets to room temperature.
5. Turn the flame size regulator back 1/2 turn counter clockwise. Attempt to light the lighter. If the lighter won’t light, turn the regulator another 1/4 turn and try again. Keep adjusting the regulator in 1/4 turns until the lighter lights
Package includes 2x jet torch lighter
Should you have any questions about the product or service,please kindly contact us via email in advance.Thank you.
LONG JET TORCH LIGHTERS-The jet flame lighter uses sturdy copper turbo nozzle, can create a continuous single flame up to 2.8 inches with a temperature of 1300°f that is easily wind resistant. No worry to light grill outdoor. 5-inch long neck design protect you from burning your hand.
Adjustable Flame & Refillable: The flame size adjustment valve can adjust the flame size at will. The lighters can be used for multiple refilling, which is more environmentally friendly and easy to use. The compact body can spray a powerful flame, and you can easily use it in various environments.
MULTIPURPOSE LIGHTER-You can use this lighter on multi applications such as grill, candle, BBQ, camping, baking, soldering or DIY jewelry or Fireplace, Gas Stove, Oven and much more. This 2 Pack Urgrette lighters are stored in a gift box, a great gifts idea for Christmas Day.
SATISFACTION GUARANTEED – We guarantee that we are honest sellers. If there are any quality problems, please feel free to email us and we will provide 24-hour online best service.
