2 Pack Candle Electric Lighter, USB Rechargeable Arc Plasma Windproof Portable Flameless Lighter, No Fuel Needed, Sleek Design, Triple Safety, Perfect for Kitchen Camping Xmas, Blue+Gold
Price: $8.08
(as of Apr 09, 2025 16:00:34 UTC – Details)
Please push up the switch gently
Product Dimensions ‏ : ‎ 7 x 0.8 x 0.45 inches; 1.06 Ounces
Date First Available ‏ : ‎ July 31, 2020
Manufacturer ‏ : ‎ LYTOWN
ASIN ‏ : ‎ B086J18S5T
ECONOMICAL & POWERFUL BATTERY – No gas required, No fluid required, No flame. Our Arc lighter is equal to 300 disposable lighters. One-Time charge can last to more than 500 times’ use. At least can be charged over 600 times. Please charge and make sure it 100% full charged when you get it. Quick charger(≥5V/2A) is not acceptable for this lighter.
WINDPROOF & PLASMA TECHNOLOGY – The Arc lighter adopt flameless plasma technology to protect the electric pulse from being blown out by strong wind or wet weather, ensures easily use it under any weather conditions, perfect and safe for daily indoor and outdoor use. Can be used for lighting tall candle jars, gas stove tops, BBQ grill, camping, fireworks, etc.
ECO FRIENDLY & CONVENIENT – The lighter uses plasma tech to eliminate the need for this harmful chemical. During the ignition, there will be gentle sound of “ zee, zee”, which is high-voltage power generation, please use with relax. USB rechargeable instead of refueling your lighter or throwing it away and buying a new one, you just connect the USB cable to a computer or a wall outlet and recharge it.
EASY TO STORE & MAINTAIN – Never put it under the sun and splashing water. To keep it in clean and dry corner in your kitchen. We provide good qualifying item for our customers. Once you are not satisfied with our product, you get a guarantee that we would give you change or refund here.
