Price: $26.99 - $9.99
(as of Mar 22, 2025 15:30:25 UTC – Details)
Quantity:You will receive two bowls and two pairs of cutleries (chopsticks,fork and spoon).
Material:The instant noodles bowls are made of wheat straw (natural organic composite) and PP material.
Color:Black bowls and white cutleries.
Size:
The large soup bowl measures about 7×2.8 in/17.8×7.1 cm.
The drain bowl measures about 6.2×2.5 in/15.7×6.4 cm.
The small bowl measures about 6×2.3 in/15.3×5.8 cm.
The fork is approximately 6.1 in/15.5 cm long.
The spoon is approximately 6.3 in/16 cm long.
The chopsticks are approximately 6.9 in/17.5 cm long.
How to use:
1.Place the noodles in a draining bowl,and place the draining bowl in a large bowl.
2.Pour an appropriate amount of water,cover the small bowl on top,and heat in the microwave.
3.After the noodles are cooked,take out the draining bowl,drain the water,put the noodles into a small bowl,mix well and set aside.
Package Content:Our ramen bowl contains a large soup bowl at the bottom(33 oz),a drain bowl in the middle and a small bowl at the top(16.9 oz).The set contains not only two bowls,but also two pairs of cutleries (chopsticks,fork and spoon).They are the perfect choice both for eating out and at home.
Premium Material:The instant noodles bowls are made of wheat straw (natural organic composite) and PP material,which is durable,healthy and BPA-free.This lightweight rapid and quick ramen cooker is portable and easy to store.Never use it in BBQ and convection mode.
Easy Operation:The ramen bowl with heat-resistant side handles can be easily and safely removed from the microwave to avoid burning your hands.It saves you time cooking ramen and is a must have for college dorms or busy adults with hungry kids.You needn’t worry about boiling water and cleaning the pot.
Creative Design:The instant noodles bowls is equipped with a side handle,allowing you to place your mobile phone upright,making it convenient to watch videos while eating.It’s so joyful to follow TV series while eating noodles.The small bowl has a tab on the bottom for easy storage of utensils.
Multipurpose:Our ramen bowl set can be directly placed in the microwave oven use.So it can be used to heat ramen,spaghetti,cheese,soup,cereal,and oatmeal.The large bowl at the bottom and the small bowl at the top can hold cereal,soup,and salad,and the drainer bowl in the middle can be used to drain noodle soup or hold fruit.
