Price: $21.10
(as of Aug 20, 2024 07:15:15 UTC – Details)
Features:
1. Completely sealed: Store your beverages in our stainless steel mugs. This travel mug has a vacuum screw lid and a leak-proof silicone ring, which can protect your mug from leaks and spills when moving.
2. Keep your beverages hot or cold: Use our stainless steel cups for hot or iced drinks. With double-wall vacuum insulation technology, these insulated cups can keep your beverage temperature for a long time. The perfect camping cup or travel cup!
Instructions:
1. Clean the cup with neutral detergent before use.
2. When using, add hot water (ice water) to preheat or pre-cool, and the heat preservation effect is better.
3. Tighten the stopper and cap in a clockwise direction to prevent leakage.
4. When drinking, unscrew the lid/open the top lid counterclockwise to pour water.
5. Unscrew the bottle stopper and directly put large ice cubes in it for storage.
Material: 304 stainless steel inside and 201 stainless steel outside
Lid: food grade PP
Capacity: 400ml/14oz, 550ml/19oz
400ml Size(about): height 16cm/6.30in ; diameter 6.5cm/2.56in
550ml Size(about): height 20cm/7.87in ; diameter 6.5cm/2.56in
Package Including
Packing List:
1*Vacuum Cup
2.The lid of the cup is splash-proof. There is a hole on the top for easy sipping. You can also use a straw through this hole. Enjoy your hot or cold drinks the way you want!
3. The inside of this double-wall vacuum-sealed coffee cup is made of food-grade 304 stainless steel. The lid is made of PP material, which is durable and safe.
4.The stainless steel cup is suitable for storing any beverage, such as wine, beer, water, juice, coffee, tea, cocktails, champagne. You can use it at the home, office, swimming pool, hot tub, gym, beach, picnic, or any other place indoors and outdoors.
5. Our coffee cups are extruded from the whole stainless steel through a huge machine, so you can see that the inner and outer walls are seamless. The appearance is elegant and contributes to hygiene and cleanliness.
