12Volt Portable Dual Zone Freezer Car Refrigerator,52Quart WIFI APP Control RV Refrigerator,Electric Fridge Cooler with LED light,-4°F∽ 68°F,12/24V DC,For Camping,Outdoor,Travel
Price: $309.98
(as of – Details)
Car Refrigerator
【DUAL ZONE&LOW NOISE】The RV refrigerator has two compartments that you can control temp respectively. The partition is detachable. It can be both a refrigerator and a freezer at the same time.The capacity of the refrigerated area is 21Quart and the freezer area is 31.7Quart.The car fridge is featured with only 45 db low noise level when it is running. Our car refrigerators can provide a silent and comfortable environment for you.This is the good choice for RV, camping, party, travel and outdoor.
【USER-RIENDLY DESIGNS & HIGH EFFICIENCY】The bottom of the camping fridge is designed to be non-slip, which can greatly reduce the lateral displacement to keep the car fridge running normally.12volt freezer adopts advanced refrigeration technology and is equipped with a powerful compressor for fast cooling. You could choose ECO mode for energy-saving or MAX mode for fast cooling.
【COOL QUICKLY & LOW VOLTAGE PROTECTION】The mini car cooler fridge is fast in cooling and easy to adjust between -4℉to 68℉ because of using the compressor. The powerful car refrigerator is equipped with 12/24V DC, which can be used in the car. The RV refrigerator provides three (low, medium, and high) voltage protection functions at different levels. This design can prevent the car power supply from being overloaded, so you don’t have to worry about running out of car power when using it.
【PREMIUM MATERIAL & PORTABLE DESIGN】The housing is made of automotive ABS and PP materials, which are durable and not easy to deform. The liner is made of food grade plastic that is safe, leak-proof. Two handles and wheels make it easy to carry or pull. A dual functioning handle allows you to carry your cooler in hand or pull it on the ground using the wheels. It’s perfect for outdoor activities.
