12 Volt Car Refrigerator, 52 Quart Portable Car Freezer with Wheels, Pull Rod, Temperature Display (-4℉-68℉), 12/24V DC & 100-240V AC, Fridge Freezer for Car, RV, Camping, Outdoor and Home Use
Price: $229.88
(as of – Details)
Car RefrigeratorCar Refrigerator
Car Refrigerator Car Refrigerator Car Refrigerator Car Refrigerator Car Refrigerator 1 HIGH QUALITY MATERIAL 2 EASY TO OPERATE 3 BATTERY PROTECTION 4 POWER SUPPLY 5 EASY TO MOVE
Car RefrigeratorCar Refrigerator 45° ANTI-SHAKE
When the car climbs at a 45 degree tilt angle, the car refrigerator can still run stably.
Car RefrigeratorCar Refrigerator CUP SLOT DESIGN
The top of the car refrigerator is equipped with four cup slots, so it is not easy to fall when placing drinks.
Car RefrigeratorCar Refrigerator EXPANDABLE COOLER
Removable bulkhead allow your car refrigerator to easily switch between full and dual zones to meet your storage needs.
Car RefrigeratorCar Refrigerator WATER DRAIN CAP
The bottom has a drain cap, easy to clean and drainage, greatly improving the efficiency of cleaning and saving time.
🚗【HOME/CAR USE & BATTERY PROTECTION SYSTEM】12v car fridge comes with 100-240v (by AC/DC adapter) and DC 12V/24V (by car cigarette lighter) for home or various vehicles such as SUV, truck, RV, etc. The refrigerator offers three different levels of battery protection (H/M/L) and compressor delay protection to prevent over-discharging of the vehicle battery, and the cooler will automatically shut down once the supply voltage falls below a set level.
🚗【PORTABLE AND DURABLE】The case is made of HDPE and PP, which is strong, durable, crash resistant and not easily deformed. The interior is made of embossed aluminum plate, which is environmentally friendly and energy-saving. Wheels, handle and pull rod design allow you to easily take your portable refrigerator anywhere.
🚗【FREEZING AND REFRIGERATION】The car refrigerator uses inverter compressor refrigeration to create an efficient, energy-saving, stable and reliable refrigeration system with a cooling range of -4°F ∽ 68°F. The interior comes with a removable bulkhead , freezing and refrigerating can be switched at will. Take the bulkhead away and you will get a 50L single storage refrigerator.
🚗【USER-FRIENDLY DESIGN】The non-slip base protects the car fridge from wear and tear and does not slide easily. When the car climbs at a 45° tilt angle, the car fridge still works properly. The bottom has a drain cap for easy cleaning and drainage. The top of the refrigerator is equipped with four cup slots to prevent drinks from being dumped. If you have any questions about our car fridge, please feel free to contact us through Amazon and we will reply you promptly.
