Price: $99.99
(as of Mar 15, 2025 08:15:18 UTC – Details)
1080P RV Backup Camera Wired System,9 inch AHD 2-Split DVR Monitor Waterproof 8LED IR Night Vision Reverse Rear View Mirror Camera 12V-24V for Semi Bus Truck Trailer Camper
Come with 5m/16ft + 15m/49ft 4-Pin aviation Extension cable suitable for Long Bus Truck Trailer RV Van Motorhome Schoolbus 5th wheel Tractor Camper Lorry Pickup all other 12V/24V heavy Duty avoid blind spot
IP69K waterproof rear mirror camera system with 4 Pin Connector, 8 LED IR Night Vison view clearly at night, 100% not wash out AHD 1080P mirror image sensor no distance lines vehicle security camera, 2.3mm lens (150°horizontal wide view angle)
9″ DVR Recording RV video monitoring system,Build in Great Loop Record functions.Max support 128GB SD(Memory excluded),Image can be rotate UP side down or mirror none mirror at your enjoy,with 2 channel video input,can display (single large video )or (2-split video )
Monitor will automatically switch for V2 when the reversing gear is selected( Monitor blue cable need to connect for gearbox reversing trigger+) V2 reversing priority
