Price: $168.99
(as of Mar 15, 2025 22:45:17 UTC – Details)
Specifications
10.36” HD Full View Digital IPS Screen
Screen Brightness: 500CD/M2, The Clearest Video Image
Effective pixels of the screen: 1600*720P
Video Recording: Support MAX 128GB SD Card
Power supply voltage: DC9V-36V
Signal format: PAL/NTSC
Working temperature: -20°C ~ +65 °C
Record resolution: 2K/4K
Split time: 2/3/5 MIN
Microphone: turn on/off
Picture mirroring: front/back/lest/right can be chosen
Camera system: 720P/1080P, PAL/NTSC
Parking monitoring: off/1/3/5/8/24 hours
Time setting: support
DVR:support
reversing line: support
reversing display: single-pic/multi-pic
reversing line adjustment:support
Screen saver:off/1 min/5 min
Language:Simplified Chinese / Traditional Chinese / English / Portuguese / Russian / Spanish / French / German / Italian / Japanese / Korean / Vietnamese / Turkish
AHD Camera
Effective pixels: 1920X1080P
Night vision: Color
Resolution: 720P/1080P
Angle: 100°H/ 60°V
Video output: AHD Video Signal
Lens focal length: 2.8MM
Waterproof: IP67
Working temperature: -30°C ~ +60 °C
Voltage: 12V
Package Included
1 X 10.36 inch Monitor
1 X 32G TF Card
1 X Power Cable
4 X AHD Camera
1 X 15M Camera Extension Cable
3 X 5M Camera Extension Cable
Screw Kit for Camera Installation
【Sound Synchronization】When the FM frequency of the monitor is adjusted to the frequency of the car radio, the sound played by the monitor can also be sent out on the car radio. This function is only used for sound transmission, the monitor cannot listen to FM stations.
【Reversing Assist&Parking Monitoring】Support the reversing auxiliary line display. Waterproof night vision camera, reversing image is clearer. Suitable for parking. Automatically switch the reversing image when reversing. After turning off the car, the camera can continue to video.
【Bluetooth & USB input】This car monitor supports Bluetooth played music, or inserts a U disk to play music or watch videos.
【Built-in Speaker】The rear view monitor has its own speaker, which can emit sound. Note that when the monitor’s FM logo is on, the monitor’s own speakers cannot produce sound. The FM switch needs to be turned off.
【Installation Tips】You can install the camera in the front/rear/left/right directions of the car. The camera trigger wire is connected to the car power ACC and the positive/left turn light/right turn light/reversing light power.
