Price: $49.90 - $33.91
(as of Feb 28, 2025 04:30:26 UTC – Details)
3 charging modes – the emergency radio with built-in 10000 mah Polymer Battery can not only be charged via a USB Type-C cable, but you can also power the emergency radio via the hand crank and solar panels to ensure that you can use the radio crank normally in an emergency.
Emergency torch and super loud SOS alarm: this solar radio has built-in 3 LED torch modes and 1.3 W reading light There is an SOS siren and Compass. SOS siren can trigger a loud alarm and can be heard far to quickly attract attention and seek help. Compass can help you not get lost.
You can quickly get the daily forecast by turning the knob instead of turning the knob up and down. FM / AM radio receives good reception and short wave transmitters even when the antenna is switched off (AM:520-1710khz, FM:87-108MHZ, NOAA:162.400-162.550MHZ).
Small and waterproof- it is small and handy (160 x90x 80 mm), a weight of 500 g, with IPX3 protected against spray water at an angle of 60°. It does not take up much space when stored, and you can carry it anywhere in any bag or handbag.
