Price: $14.99 - $13.99
(as of Aug 23, 2024 15:45:16 UTC – Details)
[Weather Radio]Aivica-088 is able to receive NOAA signal and AM&FM ,so you can gain the latest emergency weather news. And based on those information, you can make a preparation for emergency events.
[Three Power Source ] 3 power source including Hand Crank, Solar Panel, Li-ion Rechargeable Battery. Whatever you choice,it can charge your radio make it full charge.
[Power Bank] The emergency radio with a 2000mAh emergency power bank can charge your phone.The emergency radio can keep you contact with outside as well as any situations. Making safe during Hurricanes, tornadoes, rainstorms, fires or in emergencies. such as power cut or in other bad condition.
[3 LED light]The weather radio has a bright 3 LED flashlight,more brighter than other 1 LED flashlight.It has a compact size, portable in the backpack or take it away on your hand.You can use it as a flashlight. No need to panic when you in a darkness.It can totally light your way.
[SOS button] When you was in emergency push the SOS button could activates a loud alarm and a flashing red signal light by holding it,let the outside world know where you are as soon as.
