【2023 Newest】6000mAh Emergency Hand Crank Radio,Portable AM FM NOAA Weather Radio,Battery Powered Radio with 4 Built-in Charge Cable,Power Bank,LED Flashlight Reading Lamp,SOS Alarm for Emergency Home
Price: $26.95
(as of Apr 04, 2025 15:30:28 UTC – Details)
[First Emergency Radio With 4-In-1 Charging Cables] Built-in Micro, Type-C output cable, and iPhone-compatible cable support charging almost all smart devices. Newest convenient unique cable storage design, more than 5000 bending tests have proved its durability & tear resistance. If you don’t want to bring extra cables, this 4-In-1 portable emergency crank weather radio is the best choice. With the Type-C charging cable, it can charge up to 4 devices in case of emergency simultaneously.
[3 Charging Ways And 6000mAh Power Bank] Use the included Type-C cable to charge the emergency crank weather radio, which takes 5-6 hours to fully charge. It doesn’t matter if you forget the charging cable, you can charge noaa emergency weather radio through the built-in USB cable connection adapter (not included). In case of power failure, charge this crank radio with hand crank. With 4 blue power indicators, you’ll know the remaining battery power anytime and charge the weather radio in time.
[Upgraded with More Light Sources] The emergency flashlight radio upgraded with 5 lighting sources, provides you with 3 flashlight modes – Far Beam, Dipped Beam, Far&Dipped Beam for better vision in dark. Also a 6 LED reading lamp provides ample lighting for playing and reading. It’s a must to have some light backup if you reside in a location with frequent power outages. This emergency radio also equipped with an emergency SOS button, which could activate a loud SOS alarm by holding it.
[What You Get] The emergency radio hand crank solar for home outdoor survival is IPX3 waterproof and very compact for outdoor usage: weight 0.91LB only & dimension is 6.81*2.72*3.23 inch. Equipped with a portable lanyard can hanging on a travel bag. Plus, we back our emergency crank weather radio with a 12-month Warranty! Our customer service team are here for you 24/7 for anything you need and help you out. You don’t want to miss this emergency hand crank radio and just pick it up now!
