【2023 Newest】6000mAh Emergency Hand Crank Radio, AM FM NOAA Weather Radio, Survival Emergency Weather Radio with Portable Phone Charger, 3 Modes Flashlight, SOS Alarm for Hurricane, Outdoor Emergency
Price: $29.99
(as of Mar 20, 2025 02:30:25 UTC – Details)
[4 In 1 Charging Directly Anywhere ]Built-in Micro, Type-C output cable, and iPhone-compatible cable support charging almost all your smart devices. The unique cable storage design is convenient for storage cable, and more than 5000 bending tests have proved its durability and tear resistance. 4-1 portable emergency crank weather radio lets you have no need to carry any extra cables.With the included Type-C charging cable, it can charge up to 4 devices in case of emergency simultaneously.
[Provide You with More Light Sources]The emergency flashlight radio provides you with 3 flashlight modes – Far Beam, Dipped Beam & Far&Dipped Beam for better vision at night. Also included a 6LED reading lamp to provide ample lighting for play and reading. It’s a must to have some light backup if you reside in a location with frequent power outages.This emergency radio also equipped with an emergency SOS button, which could activates a loud alarm by holding it.
[3 Charging Ways] Use the included Type-C cable to charge the emergency crank weather radio, which also takes 5-6 hours to fully charge. It doesn’t matter if you forget the charging cable. You can charge noaa emergency weather radio through the built-in USB cable connection adapter (not included). In case of power failure, charge this crank radio with a hand crank. With four blue power indicators, you can know the remaining battery power at any time and charge the weather radio in time.
[What You Get]The emergency radio hand crank solar for home outdoor survival is IPX3 waterproof and very compact for outdoor usage: weight 0.91LB & dimension is 6.81*2.72*3.23 inch. Equipped with a portable lanyard can hanging on a travel bag. Plus,we back our emergency crank weather radio with a 12-month Warranty! Our customer service are here for you 24/7 for anything you need and help you out. You don’t want to miss this emergency hand crank radio and just pick it up now!
