Price: $32.90
(as of Mar 20, 2025 09:00:33 UTC – Details)
10000mAh Emergency Power Bank.
The upgraded hand crank radios with built-in 10000mAh rechargeable battery is enough to charge more than 2 phones. The radio can be used continuously for nearly 48 hours.
Short press the’SOS’button, the horn will sound an alarm, accompanied by a flashing red light, short press it again to turn off the alarm function.
The emergency flashlight radio provides:
3 modes flashlightsSuper-Bright reading lamp
Keep you and your loved ones always out of the dark when home power failure or in emergency situation.
Double speakers make the sound quality better than ever.
Loud stereo and deep bass sound allowing you to have a better experience when enjoying radio programs or musics.
Long adjustable antenna makes better reception.
Keep You And You Loved Ones Out Of The Dark In An Emergency Situation
Emergency lights for home power failure.Our solar radio will be your best survivalist gift!
Frequency Range AM 520—1710KHz; FM 87—108MHz; WB 162.400-162.550 MHz Power Supply 10000mAh / 3.7V LED Light High beam: 1W; Low beam: 1.4W; Reading light: 1.4W Dimensions 6.5*2.28*3.5 inch Weight 0.96 lbs
【10000mAh Emergency Power Bank】This hand crank radios with upgraded big capacity 10000mAh rechargeable battery, it is enough to charge more than 2 phones.3 battery backup options: Type-C charging for daily use, hand-crank generator charging and solar charging for emergency need, you will never worry it runs out of electricity! It is not only an crank emergency radio, but also an emergency power bank& phone charger.
【3 Modes LED Flashlight/ Reading Lamp】 The crank flashlight radio with 3 modes flashlight and reading lamp is a great alternative for outdoor enthusiastors or the one who need to walk dark places. The portable emergency radio can also be an emergency lights for home power failure or the best discrete survival tool you can take for all of your trips like camping,hiking…
【Double Speakers for Better Sound】The portable multi-band radio especially designed with High&Low double speakers, the stereo sounds allowing you to have a better experience when enjoying radio programs or musics. It also equipped with a 3.5mm headphone jack, you can enjoy your favorite stations without any disturb.
【Portable Radio 】This outdoor gadget is small and light, it maintains a weight of 1.16 Lb even with such a large capacity but in compact size: 6.30*3.15*1.57 inch. The portable survival radio is designed with a lanyard, suitable for outdoor carry. And we are here for you 24/7 for anything you need!
